Chevy Cavalier trac off light
KHLOW2008
  • EXPERT
What are the codes present?
Friday, December 16th, 2016 AT 4:40 PM (Merged)
DONIADAMS
C1234 LR sensor open/short
KHLOW2008
  • EXPERT
That is the Left rear sensor and the code means it is either shorted to batteery voltage or ground or has an open circuit. Since you ahve replaced the sensors and it did not work, it means you have a fault with the wiring. You need to test the wiring between the sensor and ABS control module to confirm whether it is an open or shorted circuit.
TAMMY FORGET
  • CHEVROLET CAVALIER
I am a girl. I don't know the size of my engine :roll: It's a 2002, chevy cavalier automatic. It's got 80,000 miles. I think its a 4 cylinder. But it may be a 6. (?) The check engine light comes on after the car reaches normal driving temp. Also the trac off light comes on. And if I drive very long the car will occasionally try to die on me. None of the men I know- know anything about this. I already ridiculed em all, cuz aren't all boys born with every car repair answer? :Roll: Help please?
J_GALLAGHER
The trac off light is asking for a new trany filter. I have a 2000 and when the trac light comes on it shifts very hard. There aren't any codes in the computor for it. I changed the filter an all was well.
HOLLY69DOLLY
  • 2002 CHEVROLET CAVALIER
  • 195,000 MILES
After about 20 min of driving the trac off light pops up on my dash. The car will start acting like its not getting enough gas then it will just die. I pull over give it about one min and it will crank back up drive for about 4 to 6 miles and do it again.
Friday, December 16th, 2016 AT 4:41 PM (Merged)
HMAC300
  • EXPERT
Scan for codesfirst
DAMICO454
  • 2001 CHEVROLET CAVALIER
Ok I have a cavalier and it runs pretty good I put many miles on it and just recently I have been having problems with my ABS and TRAC off and service light all on and the service with the wrench light is the one that lights. Anyways they are always on and checked all wheel sensors with ohm meter and seem to be fine checked fuses and everythign else. Now when my wife was driving the car she said that the brakes applied them self and then all of the lights came on and they went out and a few days gone by and then came on and stayed on I cant stand to look at all the lights on it looks like a damn x mas tree lit up can anyone help? I heard that the AIT sensor might be bad is this true? Help ASAP!
SERVICE WRITER
  • EXPERT
You need to have a scanner that is capable of watching the sensors inputs. It is probably a front wheel bearing. Or both. I have also seen harnesses be a source, but not nearly as often. Ohming works only sometimes.
DAMICO454
I replaced both front wheel bearings less than a year ago any other ideas. And to use a scan tool whats that usally cost at a dealer ship
SERVICE WRITER
  • EXPERT
[quote="damico454"]i replaced both front wheel bearings less than a year ago any other ideas. And to use a scan tool whats that usally cost at a dealer ship
I stand by what I first said. Even you replaced them last week. Not trying to be difficult, but I have warrantied my share of faulty bearing/hub assys. The good news is they should still be under warranty. The harnesses were also replaced?
Yeah it will cost to verify it, Its payments or repairs, no one rides for free. You don't have to go to a dealer for this.
YAP1
  • 4 CYL
  • 90,000 MILES
Transmission problem
2002 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 90000 miles
trac light just comes on car shifts real hard
RHALL77
I would suggest having the vehicle scanned for trouble codes. Is there a abs light coming on also? Get back to me with the trouble codes and ill see if I can help you
MIGHTYME552003
  • 2004 CHEVROLET CAVALIER
  • 6 CYL
  • 11,500 MILES
2004 Chevy Cavalier 6 cyl Two Wheel Drive Automatic 11500 miles
WHAT MAKES THIS LIGHT COME ON
JAMES W.
If one of your front tires spins a little faster than the other, like on ice or snow, the computer picks up on it and closes a clutch in the differential to limit the slip and help control traction.
MANNING79
  • 4 CYL
  • FWD
  • 112,000 MILES
Other Category problem
2001 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 112000 miles
I was driving down the road when my Trac off warning light came on, and I don't know why it came on. Any answers to this question would be greatly appreciated!
BMRFIXIT
  • EXPERT
Did ABS light come on two or check engine light
you can scan the car to pin point the reason
because it will range from a fuse to a sensor
AMYP0217
  • 147,284 MILES
Car acted like had loose connection with battery had trouble getting it started
Did it attempt to crank over and will not start or just won't crank over at all/nothing when you hit the key to cranking position?
AMYP0217
Attempt to crank over with few attempts and it crank
Friday, December 16th, 2016 AT 4:42 PM (Merged)
Recommended Guides
