2000 Chevy Cavalier Replaced fuel pump
AWWENDE
  • 2000 CHEVROLET CAVALIER
Engine Performance problem
2000 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I recently had to replace my fuel pump. At the time at half a tank I would have around 250 miles on the car, and would get between 29-31mpg.
after it was replaced I noticed that I run out of gas quicker. I now have around 150 miles at half a tank and get around 26mpg.
my first thought was that I must have a fuel leak. But when I checked under my car I found no drips, no puddles. I then tried reving my engine a bit to see if maybe it leaks when i'm driving, but again I didn't see a leak anywhere.
any clue what the problem is?
Do you
have the same problem?
Tuesday, December 8th, 2009 AT 2:53 PM
MMPRINCE4000
  • EXPERT
Check fuel pressure at the fuel rail with a mechanical gauge, high fuel pressure will cause mileage to go south.
Wednesday, December 9th, 2009 AT 6:08 AM
Recommended Guides
