2000 Chevy Cavalier 2000 Chevy Cavalier. Wont turn over
CINCINNATIJG26
  • 2000 CHEVROLET CAVALIER
Engine Performance problem
2000 Chevy Cavalier 4 cyl Automatic 142000 miles
I am having an issue with my 2000 cavalier. It wont kick over but tries to start. I sprayed starting fluid into the car and it started but then cut off when I wasnt spraying. What could be the issue and what can I do to fix it?
Do you
have the same problem?
Wednesday, May 27th, 2009 AT 10:35 AM
RHALL77
Listen and see if you hear your fuel pump turn on. You may have a bad fuel pump. Also see if there is fuel pressure if you do hear the pump.
Wednesday, May 27th, 2009 AT 1:49 PM
CINCINNATIJG26
I dont understand. How to I hear for the pump? I dont know what im listening for.
Wednesday, May 27th, 2009 AT 1:54 PM
RHALL77
When you turn the key on you will hear a electrical motor sound from the back of the car. Then you will know if the pump is turning on. But you should still check your fuel pressure
Wednesday, May 27th, 2009 AT 2:20 PM
Recommended Guides
