2000 Chevy Cavalier
JSHANEYFELT
  • 2000 CHEVROLET CAVALIER
Engine Performance problem
2000 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
I am workin on a 2000 model cavalier, it will not start I believe it is fuel related it is gettin fire I checked, the fuel pump is workin but is not gettin fuel to the throttle body what else could it be besides the filter?
Do you
have the same problem?
Monday, September 14th, 2009 AT 4:11 PM
MMPRINCE4000
  • EXPERT
Spray some starting fluid in the intake, if engine runs a few seconds, then it is fuel problem.
Check the fuel pressure regulator for gas in the vacuum line, if present, the FPR must be replaced.
The best approach is to measure fuel pressure with mechanical gauge. It is possible that even though the pump is running, the rubber pressure hose on the pump has ruptured and no fuel is being delivered.
Tuesday, September 15th, 2009 AT 10:00 AM
Recommended Guides
