1998 Chevy Cavalier Clutch pedal is mushy, can't shift into
ISLANDWORKER
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • MANUAL
  • 186,000 MILES
On the highway the other day I depressed the clutch and it didn't come back up. When I got the car home I found that I had no clutch fluid. Thinking that the low fluid just let air into the lines I refilled it and bed the system. Still nothing. I then determined the master cylinder was bad so I replaced that and bled the system again. This time when I tried it I get pressure but only while the engine is off. If I start the car and try the clutch looses all its pressure and I still can't shift. I know the slave is internal and a lot of work to replace so before I try and tackle that is there anything else I should try? Also, the clutch has never shown any signs of wear before. Until now it's been great. Thank for your help.
Do you
have the same problem?
Friday, December 19th, 2008 AT 9:54 PM
  • EXPERT
Hi there,
If you have not pedal pressure due to air in the line there is only 3 items that control the clutch the master cylinder the fluid line and the slave, if replacing the master has not solved your problem, I would be looking at the slave as the line would normally never give problems and a leak at a union would be very visible.
Mark (mhpautos)
Friday, December 19th, 2008 AT 11:30 PM
Recommended Guides
