1997 Chevy Cavalier Temperature Gauge Cold to Hot and back
WCAMP3711
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 97,000 MILES
Hi. About a month ago I had the coolant flushed and changed at a local quick lube. The attendant said that the wrong coolant was in the car and put the correct coolant in. He tried to get all the bubbles out and it appeared that he did. Now the temp gauge goes from cold to hot and the check engine light goes on. I pull to the side of the road and shut off the car. I heard about 5 clicking sounds after turning off the car. I let the car cool and then I drove it home. Could there be more bubbles in the coolant or is there a more serious problem?
Bill Camp
Do you
have the same problem?
Monday, December 21st, 2009 AT 9:24 PM
BMRFIXIT
  • EXPERT
Suspect and check for Low coolant
Monday, December 21st, 2009 AT 9:49 PM
Recommended Guides
