Shift cable
CAVALIER
  • 2000 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 130,000 MILES
How do I replace the shift cable on 2000 chevy cavalier mine has broken
Monday, March 14th, 2011 AT 2:00 PM
JDL
  • 16,098 POSTS
Remove the console. In the diagram # 6 is screws to remove. The round discs in the picture may be screw covers, remove to see any possible hidden screws. Check out the diagrams below Please let us know if you need anything else to get the problem fixed.
1. Open the console compartment.
2. Refer to Console Trim Plate Replacement in order to remove one of the following components:
* The console trim plate - automatic transmission
Disconnect the shift indicator connector.
* The boot - manual transmission
3. Remove the screw cover (7).
4. Remove the screws (6).
5. Remove the console (2).
Check out the diagrams (Below).
Cheers, Ken
Saturday, June 11th, 2011 AT 8:51 PM
KMORTON1
  • 1999 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 15,400 MILES
The shift cable connects to an arm that comes off of the transmission. It connects to the bottom side of the arm. What goes in it to hold it in place? Is it made together? Is there a retainer clip, or a screw or something?
Thursday, August 9th, 2018 AT 3:53 PM (Merged)
MMPRINCE4000
  • 8,549 POSTS
Should be a "U" shaped retainer clip.
KMORTON1
Thanks a lot! I actually found a mechanic to look at it last night and he told me what it looked like, circular with prongs coming off of it to hold it in. I really did not know because one of the Chevrolet dealerships told me I was going to need the whole cable when I told them I needed a clip. Just trying to make money and get over on someone probably because they think girls do not know what they are talking about. Hopefully I have the other Chevrolet dealer ordering the right clip. Thanks though.
KMORTON1
Not a U shaped clip. That clip goes up more from where I am talking about. Looked at a diagram earlier. It is where the ball at the end of the shift cable actually connects to the lever.
MMPRINCE4000
  • 8,549 POSTS
Oops I misunderstood, I thought you were talking about the cable retainer to bracket.
Gald you got it fixed.
WILLBURNROACH
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • MANUAL
  • 250,000 MILES
My cavalier isn't shifting. It's a 5 speed manual. I can run through the gears under the hood but not all of them through the gear shift. Mainly 4th and reverse on the gear shift. I removed the console and checked the cables and they both are attached and moving when I move the shifter. The linkage also moves under the hood when moving the shifter. If one of the cables are out would it still move? I was going to use the donate question but wasn't sure how much to donate.
KMORTON1
Yup thanks. It was actually really easy. I ended up just getting the whole cable
2CARPRO JACK
  • 11,533 POSTS
Yes, both cables need to move in order for the shifter to work properly. Carefully inspect the bushings where the shifter attaches to the trans arms. Also have someone shift it while you watch to see which one isnt giving what it needs to. Inspect the bushings where the cables attach to the shifter as well
MMPRINCE4000
  • 8,549 POSTS
Glad you found it, thanks for using 2carpros.
DLAMB43
  • 4 CYL
  • 175,000 MILES
I have the same problem The shift cable connects to an arm that comes off of the trans. It connects to the bottom side of the arm. What goes in it to hold it in place.... Is it made together, is there a retainer clip, or a screw or something?
I have seen a bushing for a 1999 dodge neon that looks like it would fit but I cant find where to purchase it locally so I can view it first.
Dealerships want to sell the whole cable
MADMIKE1735
  • 951 POSTS
It should be a ball and socket fit - the cable has a "socket" much like a shoulder, and presses onto the ball much like a rotater cuff in the human body. I wish there was an easy fix, but there isnt. You need the cable, and its dealer only. Chevy got ya again. Not sure what it costs, but it is a fairly easy job to tackle.
PH1415
  • 2003 CHEVROLET CAVALIER
  • 4 CYL
  • 86,000 MILES
Having problem removing shift cable harness from bracket before the firewall. Have removed both clips. Still no movement
MMPRINCE4000
  • 8,549 POSTS
If hold down clips have been removed, then use a screwdriver to pop it out. They do get rusted in the bracket and can be difficult to remove.
RDBRYC
  • 4 CYL
  • FWD
  • 99,191 MILES
I just finish an engine install in my son's 1999 cavalier with 4 spd auto trans. It won't go in to park with the console shifter. I bought the "official" GM service manual and a Haynes manual for help. They both say to put the shifter to neutral and to manually rotate the shift arm on the trans to neutral. Then "push the tab on the cable adjuster in order to adjust the cable in the cable mounting bracket". I can not find a tab or anything that looks like one on the cable assembly. Of course both manuals do not show an illustration so I could use some help.
Thanks you,
Rod
DOCFIXIT
  • 18,828 POSTS
Called "lock button" see diagram
