Ignition cylinder would not turn off
JFLUSTER
  • 1997 CHEVROLET CAVALIER
4 cyl Front Wheel Drive Automatic 137569 miles
my ignition cylinder would not turn off had to disconnect spark plugs to shut off car. Put new column in from boneyard to save money. Car starts and runs but all the idiot lights are on and theft light car has no power locks or windows basic stock car. Also no cold air from ac. Transmission codes coming up P0758 and P0753 wipers work turn signals work wheel lock works. Cant understand unhooked battery while working on column. Also test drove transmission is not working right never had any of these problems before ignition situation. Please help?
Do you
have the same problem?
Saturday, July 18th, 2009 AT 2:46 PM
M_H_RITZEL
  • EXPERT
First check all the fuses, make sure the column is grounded. When went to boneyard did they give you the column or did you pull it? If they gave you it the colimn could be from a diferent car and even though the wiring harness works could be wiring that is not compable. If everything worked ok with the old column but the ign switch was bad you can try changing the ignition switch in the old column and reinstall it.
Monday, July 20th, 2009 AT 9:47 AM
Recommended Guides
