1996 Chevy Cavalier Won't turn over in cold temps, < 20d
ROGER BELANGER
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • 75,000 MILES
I turn the key on and only the lights and radio come on. The engine wont turn over.
There is plenty of power in the battery, since I can cross the starter wires and it will start.
So to start the car I can leave the key on and cross the starter wires.
When I leave the car in the garage, it starts fine.
Any part need changing?
Roger
Do you
have the same problem?
Wednesday, March 4th, 2009 AT 1:49 PM
JDL
  • EXPERT
Hello, did you try cranking in neutral, when the problem occurs? Also check the purple wire at the S terminal at the starter solenoid, with the key in the crank position. It should be hot.
Can you tell if there is a load on the starter circuit, maybe the lites dim a little, the voltage across the battery posts drop a couple of volts, when trying to crank? Use a DMM.
Wednesday, March 4th, 2009 AT 3:12 PM
Recommended Guides
