How do you replace the TCC solenoid in my transmission?
Thursday, March 29th, 2012 AT 1:59 AM
MECHANIC
Torque Converter Clutch Solenoid Valve In transaxle valve body-you have to drop the tranny pan to get to it-
Once the pan is off it is mounted on the side of the valve body
See pic below
Image (Click to make bigger)
SPONSORED LINKS
Thursday, March 29th, 2012 AT 3:07 AM
WTC
MEMBER
2001 CHEVROLET CAVALIER
4 CYL
2WD
AUTOMATIC
63,900 MILES
Where is the torque converter clutch solenoid located
Saturday, August 31st, 2019 AT 10:06 AM
(Merged)
MECHANIC
Torque Converter Clutch (TCC) Solenoid is located-In transaxle valve body.
(Merged)
WTC
MEMBER
Thanks for the help. Now how do you change the torque converter clutch solenoid on a 2001 chevy cavalier
(Merged)
CAMAROMANANDY
MEMBER
1996 CHEVROLET CAVALIER
4 CYL
FWD
AUTOMATIC
141,000 MILES
Ive got a 96' cavalier that I think has a trans problem or a torque converter problem. When the engine is cold it will engage into gear and drive both in drive and reverse. But when the operating temp comes up then I have no movement what so ever. This happened without warning. Could the transmission go so fast that it would take out both the forward and reverse gears? Or is the torque converter fried? Or by some miricle is this an electrical issue? I also have a troulbe light but I dont have a scanner. How can I check the code without a scanner? The light may or may not be related to the trans problem
SPONSORED LINKS
(Merged)
RHALL77
MECHANIC
Have the vehicle scanned for the trouble code. Do you know if the trans is full of fluid
(Merged)
CAMAROMANANDY
MEMBER
Yes the trans is full of fluid and does not appear to be burnt
(Merged)
RHALL77
MECHANIC
Have it scanned for trouble codes and get back to me
