1996 Chevy Cavalier no brake \hazard \turn signal lights
LITLJON
  • 1996 CHEVROLET CAVALIER
Electrical problem
1996 Chevy Cavalier 4 cyl
no brake\hazard\turn signal lights, No the high mount brake light. Running lights work. Bulbs and fuses flasher good multi switch new. I do have power at fuses and the multi-switch.
WHAT else could it be?"
Do you
have the same problem?
Tuesday, March 10th, 2009 AT 4:50 PM
JACK42
How did you test the flasher unit? Looks like itis solid state. Start by testing for power at the brake light switch, orange wire should have power, then white gets it when brake applied. The 3rd brake light doesnt go through the flasher unit, should work if it has power and good bulbs. There are 3 fuses for the system, ext lp- 20 amp, turn/back up-10 amp, stop/hazard -20 amp
Wednesday, March 11th, 2009 AT 7:55 AM
Recommended Guides
