Trans fluid and filter change
MEKANIC4755
  • 2004 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
  • FWD
  • 90,000 MILES
Need to know, what kind of trans. Fluid and how much to put in my daughters little cavalier, when I change the fluid and filter. It has no dipstick just a top fill port. Thanks Terry
Saturday, February 8th, 2014 AT 5:01 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Here is a guide and some diagrams and instructions to help you get the job done.
Type - DEXRON III or Equivalent
There is a fill plug on the side which you need to get a pump for you can get it from any auto parts store for about $12.00
Check out the diagrams (Below)
Cheers, Ken
Friday, January 26th, 2018 AT 11:20 AM
TAMMYEGE
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 119,000 MILES
What type of transmission fluid should be added to my 2002 chevy cavalier z24, 2.4L engine?
Thursday, February 21st, 2019 AT 12:58 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Dexron-III auto tranny fluid is recommended.
Fluid Types
Transmission Fluid Type
Type .................... DEXRON III or Equivalent
Capacities
Transmission Fluid
Overhaul .................... 9.5L (10.0 Qt)
Here is a guide to help you service the transmission
CHILL1106
  • 2003 CHEVROLET CAVALIER
Transmission problem
2003 Chevy Cavalier Front Wheel Drive Automatic
My TRANS FLUID light came on, and then immediately went off, and hasn't come on since. I looked in the manual to see how to check fluid level, but could not find it. I went to Auto Zone, and asked the guy there how to check and what kind of fluid. He found the fill site and added half a quart of fluid. I have since found out you are not supposed to do that. Did he screw up my transmission by doing that?
BLACKOP555
  • 10,371 POSTS
He very well may help somethign screw up by doing things like that. Especially if the level was good and he overfilled it that much. Could cause the fluid to airate and then not lube properly and oxidize and not clean either. So id have a tranny flush and refil done asap.
SLICKNICX22
  • 1996 CHEVROLET CAVALIER
1996 Chevy Cavalier 4 cyl Two Wheel Drive Manual
what kind of transmission fluid do I put in my 96 cavalier with manual tranny
Thursday, February 21st, 2019 AT 12:59 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Recommended to use Synchromesh tranny fluid GM part # 12345349 and you need 2 qts
WRENCHTECH
  • 20,757 POSTS
Your car uses regular Dexron. How much it takes depends on what was done to it. If all you did was drain the pan, then it likely won't take over 4 quarts because most of the fluid staying in the Converter.
Here are the capacities
AUTOMATIC (3T40)
Bottom Pan Removal 3.8 liters (4.0 qts)
Complete Overhaul 6.6 liters (7.0 qts)
Dry 8.5 liters (9.0 qts)
AUTOMATIC (4T40-E)
Bottom Pan Removal 7.0 liters (7.4 qts)
Complete Overhaul 10.0 liters (10.6 qts)
New Converter 2.5 liters (2.6 qts)
