1995 Chevy Cavalier misses
PETEPARVIN
  • 1995 CHEVROLET CAVALIER
1995 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
my 95 cavalier misses, replaced wires and plugs ran fine before but I need help firing order is right please help
Do you
have the same problem?
Thursday, November 4th, 2010 AT 5:09 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Manifold absolute pressure sensor
Friday, November 5th, 2010 AT 6:42 AM
Recommended Guides
