I just bought a new 'used' ecm computer for my car, do you know where this computer is located on my car? Thanks!
Monday, March 23rd, 2009 AT 5:00 PM
BLUELIGHTNIN6
MECHANIC
Your vehicle's powertrain control module ( AKA electronic control module) is located on the right front of the engine compartment. Underhood near RF fender, here are the instructions on how to change it out and it shows the location in the images below.
Images (Click to make bigger)
SPONSORED LINKS
Monday, March 23rd, 2009 AT 5:13 PM
SWOOD001
MEMBER
1 POST
1998 CHEVROLET CAVALIER
4 CYL
2WD
AUTOMATIC
181,000 MILES
Where is the pcm module and how do I remove it?
Monday, January 13th, 2020 AT 8:45 PM
(Merged)
MERLIN2021
MECHANIC
Behind the right front headlight, at C1.
(Merged)
ESLAVA96
MEMBER
1 POST
1997 CHEVROLET CAVALIER
4.3L
4 CYL
2WD
AUTOMATIC
250,000 MILES
Where is the PCM ie. ECU located on this car?
(Merged)
CAR-MAN145
MECHANIC
In the right front of the engine compartment on the frame rail.
Check out the diagrams (Below)
Cheers
Image (Click to make bigger)
SPONSORED LINKS
(Merged)
ROBHUDD545
MEMBER
1996 CHEVROLET CAVALIER
4 CYL
2WD
AUTOMATIC
120,000 MILES
When I was driving it the car shutdown. When I tried to put it in park it kept rolling backwards, I had to put the emergency break on. When I turn the key to the first position some lights come on the dash. Then when I try to start the car nothing happens. I hooked up the ODBII and it did not read power from the port. I had the battery tested and it's fine. I have checked all of the fuses and they all look ok. Do you think this is the Computer? Where is the Computer located on this car?
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
T does not sounds like the computer is the problem. The ignition switch needs to be tested. Check circuits through the switch and make sure power is transferred through it. Also check the main battery cables, if they are corroded it will cause problems. Please check out and let me know.
(Merged)
ROBHUDD545
MEMBER
Thanks, I will try that today and let you know.
(Merged)
KEN L
Thank you
(Merged)
MSCRIMPER
MEMBER
Has nothing to with this problem. You gave some info for my 93 saturn windsheild wiper problem. You said wiper motor bad. Replaced this morning and all is great. Thank You.
(Merged)
ALAN BIRDSONG
MEMBER
1 POST
I was told I need anew computer my q is where it is located. I was told its behind the fender adjacent to evap canister. Is this right I cant see it and do I have to take the fender off? Please help
(Merged)
KEN L
It looks like it is down low in the front of the car, you might need to jack the car up before doing the
removal.
Cheers, Ken
SPONSORED LINKS
(Merged)
THOMASJM
MEMBER
1 POST
1994 CHEVROLET CAVALIER
4 CYL
2WD
MANUAL
300,000 MILES
Yes would like to know location of the computer for this model of chevy car. And we have just installed rebiult motor and transmission. Computer will not let us start the car. How do we reset the computer?
(Merged)
JDL
MECHANIC
The database I was looking at, shows the computer to be located under the driver side dash.
Can you communicate with the computer, does the mil come on, can you check codes?
Are you saying the vehicle cranks good, but won't start? What are you missing spark--fuel? If there is no starter action, that's not the computer.
