1994 Chevy Cavalier leaking
TAURUSMAN65
  • 1994 CHEVROLET CAVALIER
Engine Cooling problem
1994 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 156.38 miles
my car is leaking antifreeze however its not from the hoses my raditor is drained as fast as I put antifreeze in and I smell antifreeze when driving whats the problem
Do you
have the same problem?
Tuesday, December 30th, 2008 AT 11:38 AM
MMPRINCE4000
  • EXPERT
Have you checked the entire cooling system for leaks, waterpump weep hole, all hoses, radiator, heater core?
If so then if it is not leaking it, it is burning it. I would think that losing that much coolant, you would see a pretty good cloud of white smoke out the exhaust, in which case you are looking at a headgasket, or possibility an intake manifold gasket.
Perform a compression test to be sure.
Thursday, January 1st, 2009 AT 5:53 AM
Recommended Guides
