1991 Chevy Cavalier Starting
BLUE_BLAZE2001
  • 1991 CHEVROLET CAVALIER
  • 6 CYL
  • 95,000 MILES
When my car sits over night, when I try to start it in the morning it acts like it's flooded.
Do you
have the same problem?
Sunday, February 8th, 2009 AT 10:58 AM
MMPRINCE4000
  • EXPERT
Pull fuel pressure regulator vacuum line, if gas is present, the FPR had a ruptured diaphram and needs to be replaced.
Another possibility is a leaking injector. Hook up mechanical fuel pressure gauge to fuel rail test port, turn ign. "ON", then off, fuel pressure should hold at 40psi or so, for 2-3 minutes at least. If it goes down quickly, then injector or FPR as mentioned above.
Monday, February 9th, 2009 AT 7:26 AM
Recommended Guides
