1991 Chevy Cavalier
MISTERBEAFFY
  • 1991 CHEVROLET CAVALIER
1991 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
After running a 91 chevy cavalier for a good while the car will shut off. When the ignition is turned after the shutting off the car will start but when shifted into gear the car will shut off. It wont allow you to shift into gear with out shutting off until the car has remained still for a period of 20 min. Or so. What could be causing this issue?
Do you
have the same problem?
Tuesday, February 10th, 2009 AT 11:53 AM
  • EXPERT
Hi:
Is the check engine light coming on?
Tuesday, February 10th, 2009 AT 1:30 PM
Recommended Guides
