1996 Chevy Caprice
CEMORR
  • 1996 CHEVROLET CAPRICE
  • V8
  • 83,653 MILES
Changed oil, put in platinum plugs (0.050 gap) about 2 weeks ago. About 1 week ago check engine light came on. Scanned and got code P0372 timing reference high resolution signal A too few pulses. Car turns over but takes 4 or 5 tries before cranking up. Changed crank sensor, fuel filter, fuel pump relay, checked all fuses, erased code with my scanner, let idle for 10 mins. Problem still there. Help please.
Do you
have the same problem?
Tuesday, April 28th, 2009 AT 12:58 PM
  • EXPERT
Is the engine running fine but hard to start?
Monday, May 4th, 2009 AT 8:19 AM
Recommended Guides
