Ignition switch problems
CAMAROLOVER823
  • CHEVROLET CAMARO
I recently purchased a 1987 Camaro that has around 160k on it. The engine is a v8 5.0 liter 5 speed. When you try to start the car you pretty much have to use 2 hands to turn the key. Is this a problem that I can personally fix or should I have a professional do it? Also there is a small exhaust leak I believe, what are the symptoms of this?
Do you
have the same problem?
Monday, April 16th, 2007 AT 10:18 PM
MERLIN2021
  • EXPERT
Try some lock lubrication. Noise!
Tuesday, April 17th, 2007 AT 9:12 AM
Recommended Guides
