Camaro trouble
CAMAROBABE99
  • CHEVROLET CAMARO
My 1999 Camaro, (v6, 5 speed &just got over 96,000 miles) keeps dying on me. It also keeps jerking when I drive. Normally when it dies it will take up to 4 hours before it will start again. Since I had the ignition module replaced 2 weeks ago, it will start up within 5 minutes of dying. When it dies it jerks and loses RPMs. Today it did that and before I could pull over it started right back up on its own. I didn't do anything. I had the battery and altenator replaced in Nov. Of 2005. Since August of 2006, the catalytic convertor & exhaust system, brakes, clutch, fuel filter, a sensor (don't remember which one), spark plugs and wires (twice within 2 months) and the ignition module have all been replaced. No one that I've asked that has a camaro has had this problem. It doesn't make any noises or anything like that. Every place I have taken it says that if the car doesn't do what I say it does when they look at it then there is really nothing they can do about it. I have been told it is a number of different things. No one has mentioned the same thing twice. What in the world is wrong with my car?
Do you
have the same problem?
Monday, October 15th, 2007 AT 2:23 PM
MERLIN2021
  • EXPERT
Check out the Crankshaft sensor.
Monday, October 15th, 2007 AT 2:36 PM
Recommended Guides
