1996 Chevy Camaro oil pressure
SINGINGBRAD
  • 1996 CHEVROLET CAMARO
  • 6 CYL
  • 119,000 MILES
Bought camaro 3 months ago. It had engine noise, so I took it to a mechanic. He replaced the rod bearings and replaced oil pump. When I picked it up and drove it home I realized that after it warmed up the oil pressure dropped down to 0 and the engine had a small noise. The mechanic said he replaced the oil pump 3 times so there must be a problem somewhere else. What do you think the problem could be?
Do you
have the same problem?
Wednesday, August 12th, 2009 AT 9:47 AM
DOCFIXIT
  • EXPERT
Very worn cam bearings you may consider a rebuild
Wednesday, August 12th, 2009 AT 1:31 PM
Recommended Guides
