1994 Chevy Camaro not firing
CTREY.P_69
  • 1994 CHEVROLET CAMARO
  • V8
  • 109,000 MILES
I am in the military and my problem is I have a 94 z28 with lt1 its turning over but not getting any spark I changed the distributor, cap, rotor, coil, ignition module, and ignition relay fuse and still nothing. I ran a test light on the red wire on the module and there was no power to it. I tested the fuse panel inside while the car was on but not running and no fuse port lit up as having power. I checked for bad ground and there was nothing. Do you have any suggestions or ideas it would help alot thank you. My name is mikel
Do you
have the same problem?
Thursday, June 10th, 2010 AT 4:39 PM
Inspect and test the crankshaft position sensor
Thursday, June 10th, 2010 AT 4:44 PM
Recommended Guides
