1994 Chevy Camaro Need sum advice before buying Camaro!
KAUSHIKNAIR
  • 1994 CHEVROLET CAMARO
  • 6 CYL
  • 100,000 MILES
Hello im thinking about buying a 1994 camaro V6 automatic. The only problem is that the owner told me everything is fine with the car expect it wont pass smog and there's an oil leak from da bottom of the car but she doesnt know where exactly. Can u please tell me what might be the problem?Is it cheap and easy fixes?My email is kaushiknair@yahoo. Com please let me know as soon as you can!Thank you sooo much!
Do you
have the same problem?
Sunday, September 5th, 2010 AT 11:19 PM
  • EXPERT
Hi there,
Until this leak is positively identified it may need an expensive fix, if it is the rear main oil seal the transmission will have to be removed to fix it, do you know if it is an engine leak or a transmission oil leak? Is it leaking from the front of the engine or the rear? If you can get a mechanic to get it up on a hoist, they will be able to tell you more.
Mark (mhpautos)
Sunday, September 5th, 2010 AT 11:55 PM
Recommended Guides
