1992 Chevy Camaro injectors flooding cylinders
NEVADA
  • 1992 CHEVROLET CAMARO
Engine Mechanical problem
1992 Chevy Camaro 6 cyl Two Wheel Drive Automatic
1992 camaro 3.1 good fuel pressure, good spark, fuel not leaking down. New spark plugs, tryed to start it, it sounded like it wanted to start for a second then nothing just turned over, pulled the plugs and all of them were wet with gas not just a little, let blew out cylinder and let it dry out re install plug same thing, even tryed to w/o throttle no luck, it has new pressure reg, getting kind of stumped
Do you
have the same problem?
Wednesday, November 26th, 2008 AT 3:30 PM
BUDDYCRAIGG
  • EXPERT
Test for spark
Tuesday, December 9th, 2008 AT 4:44 PM
Recommended Guides
