1990 Chevy Camaro wont stay running
BSEKULO
  • 1990 CHEVROLET CAMARO
  • 6 CYL
  • 75,000 MILES
Car starts fine, and runs for about 5 mins, then slowly idles down then cuts off. If restarted imm, will start again and run for awhile and then shuts down again unless you idle up by hand then will run, but has a little roughness to it, tried fuel filter, no change. Someone said maybe injectors, or maybe a fuse for something that is burnt. Please help
Do you
have the same problem?
Sunday, July 13th, 2008 AT 11:15 AM
MUSTANG87
Idle control valve
Tuesday, July 15th, 2008 AT 11:27 PM
Recommended Guides
