1990 Chevy Camaro
RSCAMERO
  • 1990 CHEVROLET CAMARO
  • V8
  • 136,000 MILES
Car runs well but sometimes it wont even turn over when I turn the key starts right up when it wants to would you have suggestions what to look at. Replaced battery and starter alternator is good would it be in the ingnition switch or a fuse
Do you
have the same problem?
Monday, February 8th, 2010 AT 9:59 AM
JDL
  • EXPERT
Welcome to the forum. I'd check the circuits at the starter solenoid. The wiring to the S terminal is usually a purple wire, goes hot with the key in the crank position. If it isn't hot, possibilities, ignition switch, feed to or from--- neutral switch, when it acts-up did you try cranking in neutral, -- wiring circuit. If everything is hot and all cables in good shape, I'd have to check the starter.
Monday, February 8th, 2010 AT 10:28 AM
Recommended Guides
