2008 Chevy Blazer starting
DENNISKAS
  • 2008 CHEVROLET BLAZER
  • V8
  • 4WD
  • 21,000 MILES
I have had this happen a few times, put the key in and have power to everything. Turn the key to start and get noththing. I have tryed mover the gear shift, stearing wheel, un lock and lock doors. After many try's it will just start like noththing is wrong.
Any ideas
Do you
have the same problem?
Saturday, November 21st, 2009 AT 2:53 PM
Get the ignition switch tested if okay could be one of the following starter, starter relay, park/neutral switch.
Saturday, November 21st, 2009 AT 5:43 PM
STEVEN49057
When you turn key on do the dash lights come on ! & Then it will start. If you turn the key on & dash lights do not light up & it will not start, You have the same problem I am Having With my 1997 Chevy Blazer ! If you find a fix PLEASE let me Know, bassman49057@yahoo. Com THANK YOU
Sunday, November 22nd, 2009 AT 1:44 PM
Recommended Guides
