2002 Chevy Blazer
EQUALIZER27
  • 2002 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 103,000 MILES
I have an '02 Chevy Blazer. When I am making a turn the car will occasionally tremor. It doesn't happen all the time, but seems more frequent at lower speeds. It happens in both Drive and Reverse gears. I understand it could be a CV joint, but I was wondering if there is anything else. When I inspected the CV joint it had appeared to be fine.
Do you
have the same problem?
Tuesday, November 10th, 2009 AT 10:17 PM
  • EXPERT
It could be a few things. First, a CV joint will usually make a clicking sound when they are bad. Does it do that?
Next, have you checked the u-joints on the vehicle?
Finally, are the tires in good condition, free of cupping, feathering?
Friday, November 13th, 2009 AT 8:11 AM
EQUALIZER27
No click, that was why I was wondering if it could be something else.
I'll have to double check the U joint.
Tires are in practically new condition.
Tuesday, November 17th, 2009 AT 7:21 PM
Recommended Guides
