1998 Chevy Blazer Leaking coolant from?
CWDUNN8
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 130,000 MILES
I have coolant leaking from somewhere on the engine, I think I can see a little leak from between the intake and block, but the majority of the leak seems to be coming from the back of the engine where I can't see. This happens after the engine is turned off. I just replaced the water pump due to it leaking. And before that the radiator, thermostat and radiator cap due to over heating problem. No more overheating just the leaking 2 wks after replacing the water pump. Any Ideas?
Do you
have the same problem?
Tuesday, September 9th, 2008 AT 4:13 PM
MERLIN2021
  • EXPERT
A pressure test would eliminate the guessing.
Tuesday, September 9th, 2008 AT 4:20 PM
Recommended Guides
