1996 Chevy Blazer Heater Core
EDWARD POPE
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 210,001 MILES
I changed my radiator, water pump and thermostat and my truck still runs hot.
could it be my heater core (I don't have heat in the winter) I was told by Fi_esto_e that the heads was bad.
Do you
have the same problem?
Sunday, August 22nd, 2010 AT 3:12 PM
BLUELIGHTNIN6
  • EXPERT
Is the coolant leaking? Any smoke from exhaust? It could be radiator fan(s) not working, air in system, clog in system, cracked head gasket etc. If there is no leak of coolant (either visible wet spots or smoke) than it's probably a clog in the system, air in system or radiator fan(s) not coming on.
Sunday, August 22nd, 2010 AT 3:17 PM
EDWARD POPE
Now there is no smoke and no back splat from the oil and the oil is not milky
Sunday, August 22nd, 2010 AT 3:31 PM
Recommended Guides
