1996 Chevy Blazer 1996 Chevy Blazer A/C wont blow cold air
MATHYOUMAC89
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 146,000 MILES
Just bought a 96 blazer from a friend. When I turned the a/c on it would blow warm air but no cold air. I checked under the hood and the wheel on the front of the a/c compresser would spin for a couple seconds and then stop and then start again a few seconds later and then stop after a couple seconds and it kept doing this. He said the a/c works it just needed to be charged so I bought a can of 134a. When I took the cap off the accumulator tank to charge it a piece of plastic got wedged against the tongue and drained everything out of the tank. I filled the tank with the can I bought. Now when I turn on the a/c it still blows warm air but no cold air like before. However the wheel on the front of the compresser does not spin anymore. Anyone know what the problem might be?
Do you
have the same problem?
Friday, July 24th, 2009 AT 9:57 AM
BUDDYCRAIGG
  • EXPERT
You're going to need 2 more cans.
Friday, July 24th, 2009 AT 12:30 PM
Recommended Guides
