Blower motor Relay location
MARKS7V7N
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 13,500 MILES
My blower in my car recently stopped working. I was going to first check the relay to see if that was the problem, but I can't seem to locate it. Any help would be great.
Thank you
Thursday, November 27th, 2008 AT 7:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to help you test the relay after you find it from the diagrams below.
Cheers
Friday, November 28th, 2008 AT 12:53 AM
AMER126
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 180,000 MILES
My heater blows air sometimes and other times it does not. You can't hear anything, and no hot or cold air comes out. Usually in the morning it blows air just fine, but by the time I get off work it stops again. Sometimes pot holes make it work and other times it stops it from working
Some people told me its the blower relay, where is that located and which is it?
Monday, December 28th, 2020 AT 11:05 AM (Merged)
  • 108,179 POSTS
Hi:
I believe the relay is located on the passanger side under the hood to the HVAC box on the firewall. It could also be the blower motor resister, or a loose connection.
