I am trying to find a diagram of the fuse box panel
DBRAVO
  • 1988 CHEVROLET BLAZER
I am trying to find a diagram of the fuse box panel where it shows the fuses and the upper portion of the box any ideas? I have some disconnected wires that I'm having trouble locating where they belong.
Monday, November 4th, 2013 AT 2:57 PM
HMAC300
  • 48,601 POSTS
See pic if you want to find wires this may not be what you want. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Tuesday, November 5th, 2013 AT 6:28 AM
DRUNOK
  • 1983 CHEVROLET BLAZER
Electrical problem
1983 Chevy Blazer V8 Four Wheel Drive Automatic
I'm looking to buy a used '83 blazer with a 6.2 diesel engine. I found one and spoke to the owner. He told me that the starter fusible link wire has a short in it which has caused the truck from not being able to start even tho he had replaced the starter. I would like to know more info about this wire like what does it do, is it easy to replace, is there a way to start the truck without replacing the wire till I drive it home and am able to work on the truck then? Any info that you can give about this will be greatly appreciated.
Friday, March 29th, 2019 AT 2:28 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
Fusible links are nothing but large fuses in the shape of a wire. If it is burning out, it means that something that it is supplying power to is drawing too much current for some reason. Your going to have to determine what that particular link is feeding and determine which of those components is shorted or drawing too much current to melt the link.
BRANDON101
  • 1987 CHEVROLET BLAZER
Electrical problem
1987 Chevy Blazer 6 cyl Two Wheel Drive Automatic
where is the fuse located for the break lights
MIKE H R
  • 3,094 POSTS
The fuse block is located under the insrtrment panel to the left of the steering whell, the brake ligh fuse is marked stop -haz
