ABS light came on
DIANE PETERSON
  • 2002 CHEVROLET AVALANCHE
  • 5.3L
  • V8
  • 4WD
  • 200,000 MILES
ABS light came on while driving pedal goes from hard to soft. Light goes off and comes back intermittently. When light is on brakes work fine. When light goes off brakes are unreliable. Pedal gets hard and makes noise. Should we be looking at booster or sensor?
Sunday, April 23rd, 2017 AT 6:44 AM
HMAC300
  • 48,601 POSTS
When ABS light is on then the unit is not working and you just have standard power brakes if it is power. These video can help us fix it
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/rTtAnsOlZU4
Sunday, April 23rd, 2017 AT 9:00 AM
DIANE PETERSON
We had mechanic scan and two codes show sensor on right front and rear are showing error. We also checked all brake pads. Left rear pad is almost gone but other three sets all look brand new. We replaced all pads less than a year ago. Could sensors be causing that issue as well?
Sunday, April 23rd, 2017 AT 9:33 AM
HMAC300
  • 48,601 POSTS
Probably the sensor is the cause or air in ABS unit, probably both. The pad that is almost gone is more than likely the caliper is frozen or not sliding in bracket and should be fixed.
Sunday, April 23rd, 2017 AT 11:52 AM
KENNG3666
  • V8
  • 4WD
  • 84,000 MILES
I changed passenger wheel bearing and now the abs light wont go off I disconnected battery nothing bleed breaks how can sensor go bad by changing wheel bearings
Friday, February 19th, 2021 AT 11:19 AM (Merged)
RHALL77
  • 3,361 POSTS
Check and make sure you didnt crack the sensor when you removed it. Is there a way you could stop somewhere and get the ABS codes for me so I can help you the best that I can?
