1997 Chevy Astro Starting/Fuel Pump
NOTMYCUZ
  • 1997 CHEVROLET ASTRO
  • 6 CYL
  • 100,500 MILES
I ran out of gas, refueled and now it wont start. The engine cranks but wont start. I replaced fuel pump & filter 4 months ago. Back then the pump made a consistent loud whine prior to failing. When I turn the key it runs for 2 sec. And stops. Can it be a coinsidence that either the pump or regulator would go bad at the same time I run it out of gas? Is there some kind of switch or something that is keeping it from starting?
Do you
have the same problem?
Saturday, November 15th, 2008 AT 10:05 PM
Check the fuel pressure to rule out the fuel pump
Sunday, November 16th, 2008 AT 1:21 AM
Recommended Guides
