1993 Chevy Astro
JEFF464
  • 1993 CHEVROLET ASTRO
  • 6 CYL
  • FWD
  • 180,000 MILES
When pushing hatch release button nothing happens. No sound, no release. Can't open back door door. Whats wrong, what can I do?
Do you
have the same problem?
Friday, July 11th, 2008 AT 4:53 AM
JACK42
Is there a release in the back of the van?Check all fuses first with a test light. If ok you will need to climb back there and remove the plastic trim around the window, the handle has 2 10mm bolts and there are a few screws, other than that it just pops off. This will give you access to the latch assembly. Test with a light to be sure it is getting power when the button is pushed, if so replace the actuator
Friday, July 11th, 2008 AT 7:27 AM
Recommended Guides
