1986 Chevy Astro drivelin vibrations
MIGHTY OAK
  • 1986 CHEVROLET ASTRO
  • 6 CYL
  • 200,000 MILES
My van has a vibration I think is in the tourq converter or the constant velocity joint. When there is slack in the drive line it is worse. If the converter is not locked up it is not as noticable and when in a lower gear and decelerating it is not as noticable. I had the trany rebuilt with a new converter a couple of years ago. The rear end whines a little if you downshift and decelorate but makes no other noise. It seems everything on this van was used only 1 or 2 years and I have trouble finding used parts and I can't afford to buy parts that are not needed. I would appreciate if you could help. Thanks
Do you
have the same problem?
Thursday, December 3rd, 2009 AT 3:01 PM
BIGJIM79
I would try u joints first.
Sunday, December 6th, 2009 AT 2:35 AM
Recommended Guides
