Check engine light on?
FIZUL WILLIAMS
  • 1999 NISSAN PATHFINDER
  • 3.3L
  • 6 CYL
  • 4WD
  • 120,000 MILES
What cables do I need for my Genisys EVO 4, 0 scan tool in order to scan this vehicle? The scan tool tells me that I need the proper Nissan cables.
Monday, October 28th, 2019 AT 10:13 PM
STEVE W.
  • 12,963 POSTS
Welcome to 2CarPros. You need the OBD II cable with the correct key or the smart cable. You can also use the OTC 3305-141 cable if you have the correct connector. That cable is used with the adapter. However it should have the common connector. This guide can help as well
Tuesday, October 29th, 2019 AT 1:13 AM
CODYROBINSON27
  • 1998 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • MANUAL
  • 139,000 MILES
A few months back I ran up onto a 4-6" curb, ever since the yellow service engine light has been on. About a week ago, I was on a road trip and the light, all of a sudden, turned off. A couple days ago, it came back on and has been on since. I unhooked the battery and turned over the ignition for about 15seconds, rehooked the battery, and the light was still on. I am curious as to whether or not the curb I hit had anything to do with the light coming on or if it is something I should be more worried about.
Friday, October 16th, 2020 AT 1:52 PM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Well the easiest thing to do is go by your local parts store and have them pull codes, most will do it free.
Post codes here for additional help
JIMMY CLAUDIO
  • 5 POSTS
  • 1997 NISSAN PATHFINDER
  • 2.0L
  • 4 CYL
  • 4WD
  • 140,000 MILES
When I turn the key all my lights come on except for my check engine light. Where is the fuse so I can change it?
HARRY P
  • 2,293 POSTS
Hmm I would scan it and see if a code comes up stating something about the service engine light not operating. I cannot remember what the code is off hand, but I know there is one.
As far as what to change, you would need to pull the instrument cluster and check and change the bulb, as it is likely the problem. I will double check to see if there is a fuse for it somewhere, but I doubt it.
HARRY P
  • 2,293 POSTS
I double checked and do not see any special fuse for it. So it is likely just the bulb is blown or a wire is loose.
