Check engine light
CARLSTEELIE1
  • 2005 DODGE NEON
  • 4 CYL
  • FWD
  • 75,000 MILES
My check engine light came on them the car started running rough. Later the light went off and started running good. The next day the light came back on and started running rough again.
Thursday, December 3rd, 2009 AT 9:38 AM
JDL
  • 16,098 POSTS
Welcome to the forum,
Sounds like you have an intermittent cylinder misfire. have the trouble codes checked. Around here, some of the national brand auto stores will check codes for free. This will direct you to the proper cylinder that is having the issue instead of just throwing parts at it
Read the guides below they will help
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Thursday, December 3rd, 2009 AT 10:00 AM
JARED SANNER
I had this same problem. Change all your spark plugs and the check engine light should go away if this returns in a month or two then change your spark plug coil pack along with the spark plugs again and u have fixed the problem. It runs rough due to a misfire happening inside the coil or spark plugs itself it’s about a 60 dollar fix in all
Thursday, November 8th, 2018 AT 6:35 PM
LKYHEART
  • 2005 DODGE NEON
  • 4 CYL
  • FWD
  • 27,600 MILES
My engine light has been going on and off. It flashes when I push the gas, especially on the expressway. It starts to feel like it goes up and down not knowing what to do when I accelerate. We have changed the spark plugs and the light when off. In Idle sometimes it sputters as well like it wants to shut off. We bought an upstream oxygen sensor but have not put it in yet. Could it be something else? Thanks
Friday, November 9th, 2018 AT 7:31 AM (Merged)
The computer has identified a problem within the engine management system. Go to Autozone and get the OBD2 code/s pulled its a free service and comeback with the code/s this is where we start the diagnosis-without it there's no starting point-
The O2 sensor could be one of them-
BMRFIXIT
  • 19,053 POSTS
Check engine light on and flashing
you need to get the system scanned for codes
you can cycle key on off three time ending with key on
read codes in odometer area
P####
let us know of the codes
check engine light flashing its a sign of misfire check it for tune up and check the coil
Before you waste time and money on parts and sensors you should get the codes
good luck
LKYHEART
The code that popped up was P 0303. Thanks
BMRFIXIT
  • 19,053 POSTS
As you see code po303 is a misfire on cylinder # 3
i would start with a tune up
good luck
Jack
ARMYFAMILY08
Did you ever get this fixed and what was the issue. We are having the same problem and are in a pickle due to the face that we are in Germany and have limited resources. Any help would be greatly appreciated. Thank you!
CHINKEYEBANDIT
  • 2005 DODGE NEON
  • 4 CYL
  • FWD
  • 61,000 MILES
Hey my check engine light keeps coming on and going back off. The codes that come up are knock sensor and camshaft sensor. I got it checked by some mechanics and they had me to replace the knock sensor. When I did that, the check engine light came right back on. And sometimes it wont start and when im driving it tries to cut off. What could that be?
BMRFIXIT
  • 19,053 POSTS
Check engine on and flashes 9 out 0f 10 its a misfire
you had changed the plugs
I would change the wires too
check for codes
you can do that your self by cycling the key on off three times ending with key on read codes in the odometer area
BMRFIXIT
  • 19,053 POSTS
Scan for codes again
cycle key ON OFF ON OFF ON
read p codes in the odometer area
and let me know
CHINKEYEBANDIT
THE CODE was p0325.
BMRFIXIT
  • 19,053 POSTS
If the sensor was replaced
check wiring
need to check ground wire and ohm wires between PCM and sensor connector plug
BARBARA KEDROWSKI
  • 2005 DODGE NEON
  • 2.0L
  • 4 CYL
  • 180,000 MILES
Check engine light has been on for about a week, it kind of sputters when idling under 1 rpm. When going up a slight hill it starts bucking, now check engine light started flashing 10 or 11 times. Not sure because I'm driving when it happens.
STEVE W.
  • 12,950 POSTS
Flashing check engine light is your cars version of running down the street screaming for help. It means you are likely doing damage to the convertor.
Get it scanned for the codes it has. That will at least point to which area needs to be checked. It could be something simple like a bad plug or injector. Or it could be something worse. Hard to tell without knowing what the computer sees.
BARBARA KEDROWSKI
I did code check using ignition method. Got p0301. Spoke with mechanic n was told misfire on cylinder 1. So I'm hoping to be able to change plugs n wires tomorrow. And hoping it is fixed. And the light just recently came on and have been very limited on how much I drive knowing I have to fix it.
STEVE W.
  • 12,950 POSTS
Yup, P0301 is a misfire code. Could be plugs wires, coil, injector, bad valves.
Plugs and wires are a good idea, especially if they haven't been touched. Keep us informed, please.
KENATWOOD
  • 2005 DODGE NEON
  • 4 CYL
  • FWD
  • 28,000 MILES
I haven't run my car for 2 days. Today when I got in it to go to the store, I noticed my check engine light was on and was not blinking but was steady. I did the test that my manuel said to do and no blinking occurred during this test. So what is the major problem that is usually caused by this? I drove to the store and back fine which was only 2 miles each way.
I hear that it used to be the oxygen sensor that was the main reason but now days it could be anything?
CARADIODOC
  • 33,727 POSTS
You heard wrong about the oxygen sensor. It is one of the least likely to set a diagnostic fault code because so many conditions must be met.
Cycling the ignition switch used to cause the Check Engine light to flash out a series of two-digit codes that would indicate the circuit or system with a problem, not the actual component. On newer cars, the codes are displayed in the digital odometer.
The diagnostic fault codes are divided into different groups according to severity. Only the most severe will cause the Check Engine light to flash while driving. That means way too much unburned fuel is about to do permanent damage to the catalytic converter in the exhaust system.
Caradiodoc
KENATWOOD
Guess what. It is the oxygen sensor. It actually is a wire that boke in helf so I'm gonna try and splice it back together for now.
Kenatwood
