Changed cover valve gasket, now car sometimes starts
JENN POV
  • 2004 NISSAN MURANO
  • 3.5L
  • V6
  • AWD
  • 130,000 MILES
Hi, I just changed my cover valve gasket. Now the car will start sometimes but when stepping in the gas it is very low power. Could this be due to the coils or spark plugs and how do I go about checking if it is this? I already tried charging the battery. Battery is not an issue here. Please help!
Do you
have the same problem?
Sunday, May 21st, 2017 AT 10:36 AM
KEN
  • ADMIN
When you did the valve cover gasket did you remove any ground wires? This could be the problem if the wiring was not reconnected. Also I would check the air intake boot to make sure has no holes or tears in it.
Here is a guide to show you how to check.
https://www.2carpros.com/articles/replace-an-air-intake-boot
Please let us know what you find ;)
Cheers, Ken
Tuesday, May 23rd, 2017 AT 11:06 AM
Recommended Guides
