Car will not swing
DKJOHN21
  • 1989 VOLKSWAGEN JETTA
  • 2.0L
  • 4 CYL
  • MANUAL
  • 30,000 MILES
So I've striped my cars motor out and rebuild a few things, but now that I put everything back together, the car won't swing and relay by fuse box clicks every time I try and swing. All other electronics is working. Anyone that can help please?
Do you
have the same problem?
Friday, July 5th, 2019 AT 5:28 AM
PATENTED_REPAIR_PRO
  • EXPERT
I have never heard of the term 'swing" when talking about automobiles. Please explain.
Friday, July 5th, 2019 AT 5:31 AM
DKJOHN21
Won't start /won't turn over.
Friday, July 5th, 2019 AT 5:55 AM
PATENTED_REPAIR_PRO
  • EXPERT
Which relay?
Is it a no start or a no crank over with the starter?
If a no start, can you hear the fuel pump run for two seconds after you first turn the key to run?
I don't see a 2.0 engine, are you sure?
Friday, July 5th, 2019 AT 6:01 AM
Recommended Guides
