Car will not start after disconnecting battery
MLENNI
  • 2007 CHEVROLET EQUINOX
  • 3.4L
  • 6 CYL
  • 126,988 MILES
When I started the car today the radio would not turn on at all, but the car started so we disconnected the battery and reconnected and the key got stuck! The radio, lights, everything worked, but the windows and locks did not work and car would not turn over at all. I am not sure what to do or where to start.
Do you
have the same problem?
Sunday, January 29th, 2017 AT 10:37 PM
SATURNTECH9
  • EXPERT
The key was not on when you disconnected the battery and hooked it back up? Did you try to jump start it? Also, has the battery been charged and tested? Are the battery cables clean and tight?
Monday, January 30th, 2017 AT 6:21 AM
MLENNI
Battery was charged overnight. Key was not on and we tried to jump start it last night.
Monday, January 30th, 2017 AT 6:16 PM
SATURNTECH9
  • EXPERT
Does the engine crank normally and not start?Also the security light isn't on solid or flashing with the key in the run position?
Tuesday, January 31st, 2017 AT 7:20 AM
SATURNTECH9
  • EXPERT
Also why was the battery disconnected to begin with?
Tuesday, January 31st, 2017 AT 7:21 AM
MLENNI
The radio wouldn't work so we disconnected the battery. The car won't turn over at all and the screen reads service vehicle soon. There's no security light on. Windows and locks don't work either
Tuesday, January 31st, 2017 AT 9:03 AM
MLENNI
And the key is stuck in the ignition
Tuesday, January 31st, 2017 AT 9:06 AM
SATURNTECH9
  • EXPERT
You should have tried pulling all the radio fuses for ten minutes that's what your supposed to try I know you didn't know have you checked all the fuses yet?
Tuesday, January 31st, 2017 AT 10:03 AM
MLENNI
We we tested all of them they are all good and the relays are good too
Tuesday, January 31st, 2017 AT 10:19 AM
KEN
  • ADMIN
It really sounds like the battery is having a problem. Can you test it by following this guide please.
Please let us know what happens so it will help others
Best, Ken
Monday, February 6th, 2017 AT 1:34 AM
MLENNI
Thank you for your reply. We tested battery it's still good. Car reads Service vehicle soon, service air bags soon, service tire monitor system soon. Maybe body control module?
Monday, February 6th, 2017 AT 11:11 AM
STEVE W.
  • EXPERT
Try this. Disconnect the battery. Connect the two battery cables together to drain the capacitors in the system and clear any learned behavior. Reconnect the cables and see if anything has changed.
Wednesday, February 8th, 2017 AT 1:43 PM
Recommended Guides
