Car will not start after changing radio
BRENM155
  • 2007 TOYOTA COROLLA
  • 170,000 MILES
I connected the radio and everything was good. The car started and the radio functioned correctly. I left the radio on while I socketed it into place and tightened the screws. Now when I try to start the car it just makes this rapid clicking sound and the warning indicators, as well as the radio light will blink. What could be the problem?
Do you
have the same problem?
Friday, September 2nd, 2016 AT 7:30 AM
BRENM155
Update: When I loosen the negative wire, remove it, and place it back the car alarm will go off. After I tighten the negative wire back on to the battery, the alarm stops and I am able to start the car. However, I can only start the car once before I have to mess with the wire again.
Friday, September 2nd, 2016 AT 8:03 AM
HMAC300
  • EXPERT
Try resetting security system if no owners manual look online for your car on how to do it.
Friday, September 2nd, 2016 AT 9:27 AM
Recommended Guides
