Car will not start
FMARSH2005EL
  • 2005 HONDA ELEMENT
  • 2.4L
  • 4 CYL
  • 206,000 MILES
Replaced battery. We heard buzzing when we started car. Replaced starter relay, it would not start. Replaced starter, it started, put into gear (R) shut off and will not start.
Tried security steps with key fob, would not start. Attempted "clear flood" accelerator was stuck on floor pulled pedal up and tried the step, would not start. Turns over will not crank. Pulled spark plugs cleaned them.
Do you
have the same problem?
Friday, January 13th, 2017 AT 10:35 AM
KEN
  • ADMIN
Hey FMARSH2005EL,
I have to ask since so many problem happened after the battery, did the terminals get crossed when installing the battery?
Best, Ken
Wednesday, January 18th, 2017 AT 4:55 AM
FMARSH2005EL
No. Everything is installed properly. It started the one time, but when I put the car in gear (reverse) and move less than a few feet, it shut off.
Thursday, January 19th, 2017 AT 7:04 PM
KEN
  • ADMIN
So the engine does not start at all now right? I would check to see if your engine has compression does the engine sounds normal when cranking over?
Please let me know.
Best, Ken
Sunday, January 22nd, 2017 AT 10:00 AM
FMARSH2005EL
Somewhat. When I try to start it, it sounds as if it is going to. I smell gas when I stop. I just got new spark plugs to install.
Monday, January 23rd, 2017 AT 6:54 PM
KEN
  • ADMIN
While you are installing new spark plugs can you run a compression test.
Here is a guide to help you
Please let us know what happens so it will help others
Best, Ken
Friday, January 27th, 2017 AT 1:44 AM
FMARSH2005EL
I am not a mechanic so I don't have access to this equipment. The car won"t start so I can't it to get the compression test done.
Friday, January 27th, 2017 AT 6:18 PM
KEN
  • ADMIN
An auto parts store will rent it to you for free or really cheap.
Let me know how it goes
Best, Ken
Saturday, January 28th, 2017 AT 1:20 AM
FMARSH2005EL
Sure will. Thanks for the tip!
Saturday, January 28th, 2017 AT 5:12 PM
FMARSH2005EL
Compression isn't the issue. Pretty sure it's either electrical or gas related. Also, gear shift won't shift from park to neutral without using shift release slot. Brake lights aren't working. The fuses appear to all be good. About to the end of my rope with the care. :-D
Sunday, January 29th, 2017 AT 2:16 PM
KEN
  • ADMIN
Hey FMARSH2005EL,
There is a power junction block and a tail light relay that could be causing the problem, here is a wiring diagram that should help you test for power along the circuit.
Run some tests and get back to us so we can continue helping you.
Best, Ken
Monday, January 30th, 2017 AT 1:21 AM
Recommended Guides
