Car starting problem
DUSTWEB
  • 2003 CHEVROLET MALIBU
  • 3.1L
  • 6 CYL
  • FWD
  • 200,000 MILES
Sometimes when car is shut down it wont start because the security system wont let it unless you wait 10 minutes with key on.
Do you
have the same problem?
Wednesday, January 6th, 2016 AT 11:44 AM
HMAC300
  • EXPERT
Have a local pro scan for codes to see what is wrong with the system it may be the module is screwing up. Also check battery for condition including load test if it s' weak may be causing that as well.
Wednesday, January 6th, 2016 AT 12:09 PM
DUSTWEB
Have already changed and checked. Can't find an answer
Wednesday, January 6th, 2016 AT 12:37 PM
HMAC300
  • EXPERT
Try resetting like this if you had it scanned at auto parts they can't scan for that.
Wednesday, January 6th, 2016 AT 12:59 PM
Recommended Guides
