Engine will not start
NATOS
  • 2000 KIA SPORTAGE
  • 4 CYL
  • 4WD
  • 156,000 MILES
My car cranks but will not start. Thought it could be a fuel problem, changed fuel filter and gas was in the line past the filter. It had a stutter when it starts and for about the first two miles of travel, then it would run fine. Check engine light was on. Now, no check engine light and just will not start. Hooked up diagnostic to plug and got nothing, would not even power the the diagnostic.
Do you
have the same problem?
Tuesday, July 27th, 2010 AT 1:53 PM
Hi Natos, Welcome to 2CarPros.com
Check engine light coming on.
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on-let me know
Tuesday, July 27th, 2010 AT 1:59 PM
NATOS
Is there any way to check if my whole computer is bad?
The fact that the diagnostic would not power up when connected to the plug in the Kia has me thinking that it could be electrical.
All my fuses are good.
Is there a way to test the fuel pump without removing it? The screws holding it in are rusted and I will have to drill them out to remove the pump.
Tuesday, July 27th, 2010 AT 2:09 PM
You have to bring it in to the dealership to test the computer for the fuel pump. If you can hear it coming on, check the fuel pressure with a gauge to rule it out. Here is a link on how to check the fuel pressure.
Tuesday, July 27th, 2010 AT 4:40 PM
  • 2000 KIA SPORTAGE
Help!
I just replaced a blown head gasket on a 2000 Kia Sportage, aligned camshaft pulleys (dual cams) alignment marks (I on left pulley, E on right pulley) along with crankshaft alignment marks. Injectors are squirting gas, layed number one plug on engine, could see spark at plug tip while turning over, battery fully charged, just will not start or even seem like it is trying to catch. Any suggestion? Any ideas, any help would be appreciated.
RW
Thursday, August 30th, 2018 AT 12:08 PM (Merged)
  • 108,005 POSTS
If you have fuel and spark, it should run unless the timing is out (it sounds like you did it right) or there is low compression like the timing is off. Here is a guide to help confirm the issue:
If low here is a guide to help you double check the marks:
https://www.2carpros.com/diagrams/kia/sportage/2000
I want you to do a compression test on the vehicle to see if it is low. If it is, it could be a timing problem or the head gasket/head may need looked at again.
Let me know what you find.
DRITTER
  • 2000 KIA SPORTAGE
  • 65,000 MILES
The car had trouble starting the last couple days, today when I tried to start it I heard a slow, faint cranking sound twice then nothing. I was going to test the starter solenoid voltage and try the old tap on starter procedure. When we tried to start the car we noticed there seemed to be a lot of smoke coming from the starter. Should I replace the starter or look elsewhere?
  • 108,005 POSTS
If there was smoke from the starter, check to make sure the wiring to it is not damaged. If it is good, remove the starter and have it checked. It sounds bad. Note: Disconnect the battery before you work on the starter.
BSCHURR
  • 45 POSTS
If you have the four cylinder you will have to remove the intake manifold support bracket and emissions canister in engine compartment to remove starter. Have fun. Also, double check the starter Bendix tooth pattern make sure they are the same, not close. I had to replace the flywheel because I did not double check.
HASSANALARABI
  • 2000 KIA SPORTAGE
  • 4 CYL
  • 4WD
  • 300,120 MILES
The car stopped working and I check all things like fuses and fuel pump.
There is no ignition or spark or any signal even the services light are not working.
HMAC300
  • 48,606 POSTS
Check battery for condition including load test then check for master fuse blown. See picture and use a test light or volt meter to see if going through it or not. Then try resetting security system see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
CANDACE ACUFF
  • 2000 KIA SPORTAGE
  • 174,345 MILES
Starter clicks, but it will not turn over or crank.
HMAC300
  • 48,606 POSTS
Check battery for condition including load test. Then try resetting the security system.
Check out this link from the site on testing a battery:
www.2carpros. Com/articles/how-to-check-a-car-battery
ARLENE MENDOZA
  • 2000 KIA SPORTAGE
  • 2.0L
  • 4 CYL
  • 100 MILES
My car shut off on me at a red light and will not start back up. The lights and radio work so it cannot be the problem.
HMAC300
  • 48,606 POSTS
Check battery for condition including load test auto parts do for free. If you mean it turns over but will not run then scan for codes and check fuel pressure with a gauge auto parts rent it.
https://youtu.be/YV3TRZwer8k
NYOUNG34
  • 2000 KIA SPORTAGE
  • 150,000 MILES
I recently put a new starter and a new fuel pump on the car. The car stalled out but took a jump start. I was told battery was bad so I put a new battery in I also put three gallons of gas in the car using a gas can the gas gauge continues to read under E. The car cranks up but will not start. Please help! What could be wrong?
  • 52,797 POSTS
What is the exact fuel pressure. Check spark and compression as well.
NYOUNG34
Fuel pressure must be zero fuel guage is under E and wont move. How do I check the spark and compression.
  • 52,797 POSTS
Compression tester for compression and ground the coil to see if it sparks.
BELYEU
  • 2000 KIA SPORTAGE
  • 4 CYL
  • 150,000 MILES
It was running fine in December but the battery died and ever since then it will not start. It has been at the mechanic since December and the mechanic said when you spray carburetor spray on it the car will start and run until it all dries.
JAMES W.
  • 2,395 POSTS
If it runs when sprayed you need to check the fuel system to see if it is getting gas and if not. Why, fuel pump, fuse, relay etc.
