Car has been sitting in the yard sine December 24
MOLLYGANG365
  • 2000 BUICK LESABRE
  • 175,000 MILES
I have a 2000 buick lesabre limited and its stalling and shuts down while driving sometimes and sometime it wont crank after shuting down then sometime it runs good then the next minute it messes up ive already replaced the ignition coils, mass air flow, map sensor, crankshaft sensor, ignition control module, engine wire harness, air filter, fuel filter. I have a ecm I havent installed need help if its not that
Do you
have the same problem?
Sunday, June 9th, 2013 AT 9:20 PM
HMAC300
  • EXPERT
Scan for codes and check fuelpressure first
Monday, June 10th, 2013 AT 7:13 AM
Recommended Guides
