Engine stalls while driving
EMUNSANJE
  • 2000 TOYOTA NADIA
  • 1,097 MILES
Car cuts when it is on high speed 120km/h and above then when you step on the brake it cuts off, but when you are driving at 100 km/h it is okay. It does not cut when you step on the brakes. We have cleaned the plugs and the throttle body but still it cuts off?
Do you
have the same problem?
Friday, May 10th, 2013 AT 4:31 AM
KHLOW2008
  • EXPERT
That could be due to fuel starvation. Check the fuel pressure and replace the fuel filter if necessary.
Friday, May 10th, 2013 AT 11:39 AM
EMUNSANJE
Thank will do just that.
Friday, May 17th, 2013 AT 2:31 PM
KHLOW2008
  • EXPERT
Any update so far?
Sunday, May 19th, 2013 AT 12:35 AM
EMUNSANJE
After how many kilometers should I change the automatic transmission fluid (ATF)Automatic transmission?
Monday, May 20th, 2013 AT 2:51 AM
EMUNSANJE
The owner just told us that before he brought the car to us he took it for service from there the check engine started coming on. After they removed the intake manifold, even now it is on cannot get the sensor which has the problem.
Monday, May 20th, 2013 AT 4:32 AM
KHLOW2008
  • EXPERT
What is the actual mileage?
What is the trouble code?
Monday, May 20th, 2013 AT 5:22 AM
EMUNSANJE
Mileage is above 5,000 and trouble code I do not know because I do not have a diagnostic tool. I used to do it manually connecting E1 to TE1 but Nadia d4 does not have E1 and TE1.
Tuesday, May 21st, 2013 AT 1:55 AM
EMUNSANJE
How much is the diagnostic tool?
Tuesday, May 21st, 2013 AT 1:57 AM
KHLOW2008
  • EXPERT
Diagnostic tools can range from a few hundred to tens of thousands depending on what you require.
Try bridging terminal # 4 and # 12 of the diagnostic connector and check for blink codes.
Tuesday, May 21st, 2013 AT 6:52 AM
EMUNSANJE
Thanks for the reply. The front diagnostic noble does not have numbers. It has B, S1. Then the inner one does not have numbers.
Wednesday, May 22nd, 2013 AT 10:11 AM
EMUNSANJE
I mean a diagnostic code reader.
Wednesday, May 22nd, 2013 AT 10:13 AM
EMUNSANJE
I mean the diagnostic code reader.
Wednesday, May 22nd, 2013 AT 10:19 AM
KHLOW2008
  • EXPERT
The OBD-II diagnostic connector is a 16 pin connector without any numbering-s. With the wider part on top and the terminal facing, count from left to right, slot # 4. Use a jumper wire and connect this slot with the one directly below it. Turn ignition switch on and note if the check light flashes. Others such as ABS, SRS etc, might start to blink as well.
Thursday, May 23rd, 2013 AT 6:14 AM
EMUNSANJE
Thanks will just do that.
Thursday, May 23rd, 2013 AT 8:13 AM
EMUNSANJE
Hi, the code was 52(10+10+10+10+10+1+1=52).
Friday, May 24th, 2013 AT 11:51 AM
KHLOW2008
  • EXPERT
That is the knock sensor fault. Quite common for it to fail.
Check the wire connections and if they are good, have the knock sensor replaced and retest.
Friday, May 24th, 2013 AT 1:22 PM
EMUNSANJE
Okay, thanks for the reply. For the ATF when should I change it? I always do services after 5,000km that is what I tell my customers to there services (am not sure for the ATF).
Saturday, May 25th, 2013 AT 9:50 AM
KHLOW2008
  • EXPERT
My recommendation for ATF replacement interval is 20,000 to 25,000 km.
Saturday, May 25th, 2013 AT 12:57 PM
EMUNSANJE
Thanks, I am very grateful.
Sunday, May 26th, 2013 AT 7:04 AM
KHLOW2008
  • EXPERT
You are welcome.
Sunday, May 26th, 2013 AT 6:13 PM
Recommended Guides
