Car cranks but will not start
DILLON19979
  • 1998 CHEVROLET MALIBU
  • 2.4L
  • 4 CYL
  • 145 MILES
I got in my car and tried to crank it up it just engauges the starter the moter will not turn over please help
Do you
have the same problem?
Wednesday, June 17th, 2015 AT 10:05 PM
WRENCHTECH
  • EXPERT
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Thursday, June 18th, 2015 AT 2:15 AM
DILLON19979
The theft light stays on all the time could that have something to do with it I cut the speaker wires in the door to shut the driver side speaker up could that be where my problem lies or maybe just the ignition switch
Friday, June 19th, 2015 AT 8:45 PM
WRENCHTECH
  • EXPERT
The Passlock system would cause it to start and stall immediately if it was disabling the engine. You probably should have the codes read anyway to find out why that light is on but in the meantime perform all the testing I gave you.
Saturday, June 20th, 2015 AT 4:58 AM
Recommended Guides
