Car as been to 4 shops need help asap
MOLLYGANG365
  • 2000 BUICK LESABRE
  • 175,000 MILES
I have a 2000 buick lesabre limited 3800 series 2 it dies when put in gear then it'll run if I keep my foot on the pedal at idle and even when im doing that it the rpm drop and the engine sputters and trys to cut off and I have to press it down more it keep it running it dies while driving to and when a part is replaced it runs for a litlle while then die agin car already been to 4 shops
Parts Already Replaced
MAF Sensor
MAP Sensor
Throttle Position Sensor
Idle air control sensor
Coil Packs
Spark Plugs & Wires
Ignition Module
Fuel Pump
Crankshaft Postion Sensor
and more
Do you
have the same problem?
Saturday, July 6th, 2013 AT 1:12 AM
HMAC300
  • EXPERT
Scan for codes and check fuel pressure first
Saturday, July 6th, 2013 AT 5:52 AM
Recommended Guides
